Salta al contenuto principale
The Asus ROG Strix GL702VS gaming laptop is a lightweight laptop specifically used for gaming. It uses an i7 core processor and mobile 1070 graphics card.
2 Domande Visualizza tutte
Asus ROG GL502VSK Battery Replacement
Hi,
I've got a Asus ROG GL502VSK laptop which its battery is completely dead. I could not find an exact battery for this model and I was wondering if the Asus ROG Strix Battery which is available on this site, is compatible with my model and fits inside the chassis of my GL502VSK
This is the link to the available battery:
Thanks in advance
Immagine Replace a 4840 mAh battery compatible with Asus ROG Strix laptops. 76 Watt Hours. 15.2 Volts (V). Part #C41N1541, C41PP91, 0B200-02070000, 0B200-02070200, 0B200-02070300
Prodotto
$79.99
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
@pouriyajamshidi best thing to do, would be to contact Customer support and see what they tell you. You can contact them by various means as listed here https://help.ifixit.com/category/133-con...
I did check the compatibility for this battery and it does NOT look like it will work. Your ASUS needs a C41N1531 and the one listed is a C41N1541 Does not look like iFixit has those in stock. Again Customer service can definitely help you with that.
Punteggio 2
1 Commento:
Thank you for your time and help @oldturkey03
I will contact them and see what they say.
da
Aggiungi la tua risposta
Pouriya sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 195
