Salta al contenuto principale
A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
How is the lcd backlight powered
I'm trying to repair my Touchpad from a water spill. The digitizer and lcd seem ok and are responsive. The screen doesn't light however. Does anyone know where the backlight is powered from (maybe lcd cable or some other contact on the board) or if it can be replaced if needs be?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
i'm afraid that the backlight power is on the same wire with the screen. So if there is a problem with the backlight means that you have to change your screen to fix it.
Punteggio 1
Aggiungi la tua risposta
Mark Turner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 902
