Salta al contenuto principale
Can you change the gpu on an acer Aspire 3?
Can you change the gpu on this laptop?
Questa è una buona domanda?
Punteggio 0
1 Commento
Hey there, I updated your question a bit to add a little bit more clarity.
da
Aggiungi un commento
2 Risposte
To put it bluntly, no. To put it not as bluntly, the issue with upgrading most gaming laptops is that components like CPUs and GPUs are typically integrated directly into the motherboard. This makes upgrading these specific components difficult. Normally I would suggest using an eGPU, however, it does not seem that the Aspire 3 has Thunderbolt support.
I also saw some of your other questions. You can also speed up your machine by upgrading the RAM and an SSD.
Punteggio 1
Risposta Più Utile
yeah, you can't unfortunately, it even says it on the acer website https://community.acer.com/en/discussion...
hope this helps!
Punteggio 1
Aggiungi la tua risposta
Hello sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 31
Tutti i Tempi: 581
