Salta al contenuto principale
Informazioni su riparazione e smontaggio dell'iPhone SE di seconda generazione, annunciato e lanciato sul mercato nell'aprile 2020.
239 Domande Visualizza tutte
iPhone screen still frozen after I restored it
I had a problem with my iphone screen being frozen even after trying to restart it multible times. I tried to do a restore to the original settings and erased all of my data and it Still has a frozen screens. this phone is only 1 month old.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
If your screen is black or frozen
Press and quickly release the volume up button.
Press and quickly release the volume down button.
Press and hold the side button until you see the Apple logo.
If your phone doesn't turn on, follow these steps to check your hardware and charge your phone.
Regards,
Diana
Punteggio 0
You can try the following solutions when your iPhone is frozen:
  1. Re-charge your iPhone
# Force-close unresponsive apps if your iPhone is frozen in certain apps
  1. Force restart your iPhone
  2. Restore iPhone to factory settings using iTunes if factory reset doesn't work on iPhone
If none of the solutions works, you can try to put your iPhone into recovery mode and let iTunes help you troubleshoot.
Since the last two solutions will erase all settings and data from your iPhone, you'd better full backup your iPhone in advance. you can rely on iTunes or a third-party tool like FoneTool (quicker and easier) to make it.
Punteggio 0
Aggiungi la tua risposta
Stink Ified sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 105
