Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
LCD connector issue and replacement
so my iphone backlights doesn't work very well and only flashes when i either lock/unlock it, i think it must be the problem of LCD connector.
is there any ways to buy the part and replace it?
please help, and thank you.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The connector on the LCD part is not replaceable without buying a new screen (which sounds like a more promising possibility).
If you want to replace the connector on the iPhone logic board, you'd need to find a replacement connector through an electronics catalog or something and have an extremely experienced solderer replace the connector for you. Even then, the chances are extremely slim.
It sounds to me like replacing the display is what might most likely solve your problem.
This is the part you'll need.
Punteggio 0
2 Commenti:
thank you!
look into the price and wow i'd rather buy a new iphone then.
da
you don't have to buy here..or buy the whole front display. you only need the LCD!
da
Risposta Più Utile
Another thing to consider is the backlight for the 3gs is "powered" by a coil on the logicboard have a search for 'Part 6R8 Coil' for info
Punteggio 1
Aggiungi la tua risposta
doa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,299
