Salta al contenuto principale
MacBook Pro A1211 power light not lighting up.
Hi guys,
I have a Macbook Pro(Apple A1211) and when i plug the charger into it the green light doesn't turn on. I have tried to disconnect and plug the CMOS battery back in, have tried to take the left I/O board out and put it back in and I have also tried to plug the grey and black power cable back in but it still doesn't do anything. I don't know what is going on with it. Please help
Update (04/10/23)
Hi guys i now have another problem.
The laptop turns on, but there is not boot chime or display and the fans are running but the screen is completely black. I have tried to disconnect the display and plug it back in but it did not do anything. This is a new display and it did say on the description that it was working but it does not show anything on the display and i don't know why. I have also tried resetting the NVRAM or PRAM but it still doesnt do anything. Please help
Questa è una buona domanda?
Punteggio 1
1 Commento
Does It have a battery?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Could you disconnect the display and plug in an external monitor to see if you get video output?
Punteggio 2
4 Commenti:
I have tried to connect to my monitor with a DVI to HDMI cable and it still says no signal and i don't know what to do :(
da
@maxplayz - Not good 😖
This sounds like a deeper issue in the main logic board. Likely a blown GPU which was common in this series.
da
I just bought a new logic board though!
da
@maxplayz - This series logic boards had there fair share of issues! The board you bought likely used with little or no testing.
This system will require a lot of TLC to make workable with the supported OS9 or early OS-X it could run. As a working collectible it has more value.
Trying to make it more than it was is both a waste of time and money.
The world has moved on and any data on this system is likely a bit to exposed on the internet.
Think it this way seeing an old Ford Model T in a parade makes sense, seeing someone driving on the Autobahn as their mode of transit is foolhardy!
da
The MacBook Pro 15" (Model A1211) Left I/O Board may need replacing.
What is your aim here? The OS’s this system uses as well as Applications are quite limited.
Immagine MacBook Pro 15" (Model A1211) Left I/O Board
Prodotto
$29.99
Punteggio 1
2 Commenti:
I am trying to install an unsupported version of MacOS on it but it keeps coming up with errors when I do it
da
@maxplayz - I would focus on the power issue before messing with running a newer OS.
da
Aggiungi la tua risposta
Max Playz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 70
