Salta al contenuto principale
Successore della PowerShot G7 X, la Mark II è stata lanciata come modello di punta di Canon nel 2016.
Camera forgets date and time every time I take the battery out
Hiya, every time I take my battery out of the camera, even just for a few seconds, the camera forgets the date and time and I have to keep inputing the information. Is there a way I might be able to fix this?
Questa è una buona domanda?
Punteggio 2
1 Commento
You will probably have to replace the backup battery. Unfortunately, I can't find any information on where the backup battery is stored.
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi Lulu,
According to the Camera User Guide, there is indeed a dedicated date/time battery, aka the backup battery. Here's what it had to say.
  • The camera has a built-in date/time battery (backup battery). Date/time settings can be retained for about 3 weeks after the battery pack is removed.
  • The date/time battery will be charged in about 4 hours once you insert a charged battery pack, even if power to the camera is turned off.
  • Once the date/time battery is depleted, the [Date/Time] screen will be displayed when you turn the camera on. Set the correct date and time as described in "Setting the Date and Time" (pg 20).
No luck finding any actual information on where that battery is located, what type of battery it is, or how to replace it. One repair site that has "advisors" available pointed out a couple of sites (one of them being iFixit) showing the replacement procedure for that battery on other models of Canon cameras. No idea if they'll help, but here they are.
Canon Knowledge Base - Replacing the date battery PowerShot A530 and A540
Canon PowerShot SX160 IS Clock Battery Replacement - iFixit Repair Guide
Let us know if you get this figured out; there are definitely other people who have looked for an answer to this same question with no luck.
Punteggio 1
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 17
Ultimi 30 giorni: 69
Tutti i Tempi: 2,205
