Salta al contenuto principale
The Stylo 2V is a USA-exclusive slate-form stylus-enabled Android phablet released in 2016 for use on the Verizon network. Identifiable by model number VS835.
Why is my phone in a reboot loop
The phone will restart over and over again. Sometimes I can't even turn the phone on.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
you need to restore/recover android on your LG
i found a guide that will walk you through how to do this for your model
https://www.youtube.com/watch?v=bsxUBHox...
Punteggio 1
where is my comment, can anyone tell me
Punteggio 0
Common issue on this model (on many LG phones in general. The memory chip lose contact with mainboard, permanent fix is reball the chip. Temporary solution is heat up the phone with hair dryer on cca 60°C, the metal contact will lettle bit expand and Temporary will be there electric contact. I recomend this solution only for turn on the phone and také important data. There is no way to fix with any software becouse is hardware problem.
Punteggio 0
Aggiungi la tua risposta
Joey Andersen (AwesomeWolfjj) sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 152
