Salta al contenuto principale
Ripara quell'orologio da polso usando una delle nostre pratiche guide!
53 Domande Visualizza tutte
Tool to open expensive watch It's a Seiko.
Which tool do you recommend for prying open my classic wristwatch to replace the battery. Watch shops charge too much for this simple task. It's a Seiko.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi @joelsilverman
If the back of the watch has notches, here's a video that may help.
If it has what is known as a snap off back then this video may help.
Update (03/30/23)
Hi @joelsilverman
I think that the only two that may have a chance (depends on the size of the gap between the cover and the watch frame) would be these
Jimmy
iFixit Opening Tool
Immagine Jimmy
Prodotto
Jimmy
$7.99
Immagine iFixit Opening Tool
Prodotto
iFixit Opening Tool
Punteggio 3
1 Commento:
Thanks. It's the snap-off type. Which tool does iFixit offer that would work?
da
Watchmaking has long history and tradition that it should be considered its own category, with specialized toolset and skillset.
What you are looking for is case openers that are made specifically for the type of cases your watch has, be it a clip-on or screw-back cases.
Punteggio 0
Aggiungi la tua risposta
Joel Silverman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 72
