How do I remove the headphone assembly
How do I remove then replace the headphone assembly?
Questa è una buona domanda?
It’s a bit of a chore as you need to remove the logic board to gain access to the assembly which sits partway under it. If you review the older 2016 teardown here you can see it in Step 19 Smontaggio MacBook Pro 13" Function Keys versione fine 2016 which is exactly the same setup
But before you do this what is your problem as there maybe an easier fix.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 14
