My left joystick is stuck plz help
my left joystick is stuck plz help i dropped it 1 day a go its will not go down
Questa è una buona domanda?
the stick seems broken and stuck so you will need too get it repaired
not sure if this applies to the switch lite, but I've found some joysticks get stuck if you push them too far. Try gently wiggling it and it might pop back into place
If it is stuck by a foreign object, remove the case and remove it. If not, the joystick may be broken. Just replace it
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 81
