Salta al contenuto principale
Released in Sept, 2018 by OPPO
WiFi, Bluetooth and Hotspot not working in my Realme C11
How do I fix them please?
Questa è una buona domanda?
Punteggio 9
3 Commenti
Hotspot is not playing from my phone to desktop
da
Signal lost connection
da
To change display
Battery change
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
If you're experiencing issues with WiFi, Bluetooth, and Hotspot on your Realme C11, there are several steps you can take to fix the problem. First, check your network settings to make sure that these features are enabled. You can also try restarting your device or clearing the cache and data of the affected app. Additionally, ensure that your device has the latest software updates installed. If none of these solutions work, you can try resetting your network settings or performing a factory reset on your device. However, it's important to note that a factory reset will erase all data and settings on your device, so be sure to back up your important data before proceeding. If the issue persists, contact Realme customer support for further assistance.
source
Punteggio 3
1 Commento:
I'm doing all but still same problem
da
Charging problem
Punteggio 1
Aggiungi la tua risposta
Tobias Muchiri sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 46
Tutti i Tempi: 2,838
