Salta al contenuto principale
Ifixit Battery Not Detected After Replacement
I replaced a dying (or dead) dell battery with one I just got from ifixit. The replacement seemed simple enough but now I'm not seeing any power options and upon running diagnostics it says there is no battery?!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Are you currently plugged in the charger? If so, remove it and try to start the laptop again. If it doesn't work, you probably did not connect the battery correctly.
Punteggio 0
Aggiungi la tua risposta
Nadir Sharif sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 116
