Salta al contenuto principale
La versione aggiornata del Nintendo 3DS da parte di Nintendo. Presenta schermi più grandi, una maggiore durata della batteria, una densità di pixel migliorata e un design più curato.
Liquid in the digitizer
hey,
so my kids somehow managed to get water inside the digitzer, i tore the device down and its solely the digitizer from the inside, i have let it sit with some silica gel for 10 hours already but there is no sign of the moisture disappearing, i was wondering if i could heat it up with a heat gun/hair dryer so it evaporates faster
thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Hi
I wouldn’t recommend heating the display as you will most likely burn the glue in between the layers
Unfortunately you may have to buy a new one unless you want to take a gamble
You could also try and disassemble the backlight as that’s where most of the water will gather but please do this at your own risk
Hopefully this helps
Any questions please ask
Punteggio 0
4 Commenti:
the thing is, its not the LCD its the digitizer i was wondering if i could heat it up
da
@hajis
If you use heat below 120deg c you might get away with it
Probably needs replacing though
I would attempt at your own risk:-)
da
alright thank you ill try my luck
da
@hajis
Good luck!
Btw I meant 120deg c not 12 XD
da
Aggiungi la tua risposta
hajis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 90
