Salta al contenuto principale
The Theragun Elite is a massage gun from Therabody.
Anyone completed a battery repair/replacement?
Mine has just stopped taking charge.
Oh, the on button is broken as well...
EDIT:
It's the Theragun Elite (https://www.therabody.com/uk/en-gb/elite...) from a few years back - there is no swappable battery. Will post pictures tomorrow.
EDIT 31/12/2024
Still not completely given up and still massively encouraged and grateful for commenters so far - thank you.
Found this page that shows the battery in question but I can't read the langauge so no idea...I can't find a replacement battery, sadly.
10.8V锂电池组,6V电源适配器,数显光纤放大器 - 〓器材友情交换〓 - 矿石收音机论坛 - Powered by Discuz!
Update (12/31/24)
Theragun Elite (white) pictures to support recent teardown efforts.
Still not found a battery source.
Questa è una buona domanda?
Punteggio 7
Aggiungi un commento
14 Risposte
Soluzione Prescelta
@ststom I would check videos like like this one (lot's of smack talk) to get to the circuit boards (that'll help for the switch repair). As for the repair, not sure if you are thinking of repairing the batteries. That is actually relatively easy to do. All you need to do is to crack the case open and replace the 4 18650 2500mAh 30A (LR1865LD) batteries. Cost is about USD $6-$8 per piece. The cells are identical between Theragun models, but there seem to be changes in battery controller.
Theragun Pro 2
Theragun Pro 3
While you replace your battery and fix your switch, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Update (03/15/23)
@ststom looks like the same pain to take it apart, but I like the battery better. No hard case. Plastic wrap can be cut and removed. I would even bet it's the same cells in there :-)
Same principle different model. You got this!
Punteggio 5
16 Commenti:
Thank you very much.
da
Just seen the update. Thank you!
da
Hi all, I've also got this issue and have tried following the video above, but the casing on the Pro and the Elite are different. I've removed the plastic cover and all the screws, but can't see a way in after that - I don't want to wreck the casing any more than I already have. Did you take pics @STSTom ?
da
@chrisbower If you want to post some pictures as an answer or even better create your own question. We can always fix the layout of this question later. Lets see what you got going on there.
da
Mostra altri 11 commenti
I agree with the above and got it working again.
Its a %#*@ hard unit to open up, you need to pry the covers off the sides of the unit as well as the one on the handle. Take the screws out and then pry open the lower handle enough to get the battery unit out. This saves taking off the blue end of the unit where the part is that hammers.
I just attached a 6volt battery into the circuit (positive to positive etc) and it was enough to get a bit of a charge and shock the batteries into charging again when you plug it back in. I'm sure a 12 volt battery would have been better but thats all I has and it seemed to work.
Good luck.
Punteggio 4
Wanted to post an update here since it looks like h1791story hasn’t yet.
I was having a problem with my unit showing that it was charged to 100%, but once disconnected, it would not turn on. When I would plug it in again, the charging indicator showed 0% and the process would reatart
I opened my Theragun Elite and tested the 18650 batteries with a multimeter - read as 0.3 V each, so this confirmed that there was a problem with the battery to the point where it wasn’t able to be recharged anymore. It seems the internals are not truly in sync with the battery, so it would read as charged to 100% even though the battery was not accepting charge at this low voltage.
I am a beginner at spot welding and handling 18650 batteries, but it was fairly easy to disconnect the 3 native batteries from the circuit and spot weld 3 new batteries (I purchased 2500 mAh 20A from bulkbattery) that were in series. I wasn’t able to record, but there are tons of guides on YouTube on how to spot weld 18650s, so I would reference any of those.
Once connected, the unit works again and also has an accurate charging indicator. Hope this helps someone - I am an absolute beginner with DIY projects but this was very manageable and fun to learn about the capabilities of 18650 li-ion batteries. Happy to answer any questions!
Punteggio 2
2 Commenti:
@brandonbui74869
Hey I’ve got the new batteries in and the unit is running however I didn’t write down how I needed to hook up the red and the black cables coming out of the board that’s in the battery pack for charging. Anyway I attach it I’m not gaining any charge. Do you know how those were wired or have pictures?
da
Can someone please post pics or describe how they disassembled the elite to get to the batteries. Where are they located? I've been able to remove the plastic on the switch side but the other 2 sides are not coming apart very easy. I don't want to break things if those sides are not needed.
da
There's a lot of mentions regarding essentially jumpstarting the dead battery cell (the 3 18650's soldered together) on the Theragun Elite, but I'm seeing a lot of conflicting info online where it's not recommended to do something like that due to the fact that if the batteries have discharged to a level where they cannot hold a charge, the chemical changes the battery undergoes makes it dangerous to revive. That is, fire/explosion risks.
Anybody more experienced with batteries/18650's that can shine a light on this? Debating if it's worth it to perform something like this or to get new batteries altogether.
-- UPDATE --
For anyone running into this post in the future, I can provide some data-points on my theragun elite.
Had a brand new gun sitting unused for 3-4 years. Opened it up and it wouldn't take a charge. It would take 10+ hours from 0-100%, and once unplugged, drop back down to 0.
Followed some helpful comments here and https://www.youtube.com/watch?v=_-uEJRH-... to get the gun opened, pulled out the battery and unwrapped it.
You will need a multimeter. Multimeter measured voltages of each cell at 0.2-0.3V each. Didn't have any other special tools on me other than a wire stripping tool and an 18650 battery charger. Harvested a working 18650 battery from an old laptop battery (you should buy one if you can't find a spare), measured it at ~2.6v and thankfully it charged up fully with the battery charger.
Stripped an old usb charging cable and pulled out the red and black wires for positive/negative charging. They were extremely thin but worked. Followed this video https://www.youtube.com/watch?v=orvdFk23... and used the wires to connect each cell of my battery pack to my fully charged cell, and got them each to ~2.5V. Plugged in the massage gun charger and this time around, started charging really quickly.
Constantly made sure batteries did not get exceedingly hot. One of them were slightly warm at most. At ~50% charge, I unplugged the charger and let it sit for an hour/overnight. Both incurred a 0.02V drop which I was happy about. Charged it up to 100% and each cell measured at ~4.10V. Gun started up and works fine now.
Punteggio 2
I just repaired one and It was hard to get it apart. The battery was a 3 cell and soldered on. 2 of the cells dropped below the cutoff voltage and the unit wouldn't charger I was able to get the unit apart just input to let the battery pack hang out. I cut the plastic off the battery and used a cheap charger to get each cell up to about 3v. The unit started taking a charge have I got the voltage up.
Punteggio 1
2 Commenti:
Cheers, OG Style. This is the same silhouette as mine. Any tips on getting the unit opened up? Battery pack fixed in there at all? What's the charger you used? Not the Theragun one?
da
I wasn't able to get the unit fully apart. I got it open enough to pull the battery out.
The charger is a really cheap 18650 charger. The model is Yonii C1. My nice charger would work and showed that the batteries were bad.
I fixed a Elite model.
da
Yes today was easy all did was shock battery already in and worked instantly used ryobi 18v drill battery
Punteggio 1
3 Commenti:
What does this mean and how do you do it? I like that it was easy!
da
I think I know what this shock the battery means but don't understand I have only done it to dead batteries that been in storage and would t charge on the charger the battery came with I would touch the + & - with 12 volt car battery then try on the charger usually works Everytime but a fully charged battery this gun is put together well so if I cut a c cord that charged it test the wires for positive negative then polarize them for a second this should work if it's not the switch .
da
All battery needs is 2min shock to regain charging life bck into it
da
@brandonbui74869 are you in the UK? I have exactly the same problem with mine and I haven't got a clue on how to fix it. I am female (I know that's not a good excuse) but don't believe I would be able to do it
Punteggio 1
1 Commento:
Definitely don't support the idea you should struggle more because you're a female. Hope you got sorted.
da
Yes open device up and the battery fine it just needs little jump with wire from 18v drill charger just tap on battery port few times will start charging again
Punteggio 1
I recently got a second-hand Theragun Elite G3 (the one with DC 4017 powerwell input) for 350 RMB (about 50USD) from Xianyu (the largest second-hand/personal website from Alibaba), and the battery seems dead. And I tore it down according to the helpful guidelines above.
The battery uses three Samsung 25R 18650 lithium-ion batteries, which were connected in a serial way; in my case, they were tested using a multimeter; two of them had an open-circuit voltage of about 0 volts, which indicates their SOC(state of charge) is in a negative state. This is normally what is called extreme overdischarge. One of them is overdischarged, its open-circuit voltage is at about 2.5V. They were connected to the machine by a protective board, and the power cable was soldered to the control board. Three extra cables using a JST connector transmit the NTC signal (thermal information of each battery) from three electric thermocouples. The device won't boot or show anything if these 3 NTC signals are absent.
So I tried to use a digital-controlled-adjustable power source to charge the two dead ones, and closely monitor them using a thermo camera, unfortunately, that didn't do much help. *(This is a bit dangerous, and if you don't know what you are doing and do not have any experience with Lithium-ion batteries, please DO NOT try this at home).
The model for the battery is TG-G3-25S, and I was able to find them brand new at a cheap price on Xianyu for 59RMB (approximately 8.28 USD at this time). The seller was from Zhuhai, Guangdong, which is where the battery and the Theragun manufacturing factory are located. I assume there were spare parts from the factory. The battery's manufacturing date was 2020, and the seller promised me they were never used and were in a proper state.
I also noticed there were other models from other buyers in models such as Elite-QR001B-RBA (2023-11-28), TB-F1-01 ......, there were also swappable batteries for G3/G4 pro, and the latest model, which has a type-C port, not a DC 17 diameter port like the legacy one. But I don't need them, so I gave up buying them. I also bought some motors from Theragun because they look nice, and they might come in handy. The 12V motor can be purchased at Taobao at about 10 RMB - 20RMB, depending on the model. I got a BL3435, BL4539P-L, and a BL2827S for 40 RMB total.
The battery hasn't arrived, so I would wait and see how they are when they arrive.
The information above is to help someone who can't find an alternative, and their battery cell might be dead like mine. Personally, I won't recommend anyone buy a Theragun. They intentionally make it hard to open and repair things; it would come off easily if not the massage tips were designed like this
. I guess someone could use an electric grinder pen to remove the pressed metal, which prevents the nylon plastic cover from coming off, and then the plastic and stuff would come off.
Update (09/13/25)
The protective board uses the BM3451SMDC-T28A, which is a rare component. I can't wrap my head around how cells like Samsung 25R, which have a good reputation, would overdischarge like this. There must be something wrong with their battery management solution to have such a wide range of battery failures. According to the datasheet, BM3451SMDC-T28A has charge balance and overcharge protection. I never use components from BYD IC, and I think they really shouldn't cut corners on these things, or maybe they did this on purpose? Texas Instruments has far superior solutions for battery management. As a so-called California Brand, they really used as much cheap Chinese IC as possible to reduce costs. And I suspect that everything of their electrical design is outsourced to a not-so-great engineering team with little durability and longevity testing.
Update (09/16/25)
Charge the new battery to approximately 10V, as it has been in the warehouse for 4 years, according to its marking. and connect it to the logic board, and voila, everything runs fine. Just cut the old battery off and connect them properly like I do, keep an eye on the length of the wire, I made a mistake and have to cut them short, that's unnecessary and exhausting.
Punteggio 1
I have a Theragun PRO Generation 4. My batteries are only charging to about 25% and their life when massaging is miserable. Therabody tells me they don't make replacements anymore! I thought Apple was bad! I found this article and was optimistic. I have removable batteries. I'm looking at my battery enclosure, but I'm not sure how to 'crack' it open. It has an endcap that is rounded and is the part on the exterior when inserted into the Theragun. I was able to pop this off without much difficulty. Now I'm looking at the long tube the batteries are enclosed in with 'cracks' up each side. Do I just pry on these with a nylon case opener? I don't want to break the battery enclosure since I can't get replacements from Therabody. They have useless customer service. Thanks in advance! This would definitely prolong the life of my Theragun! It's still great except for the batteries. I even considered converting it into a pluggable, but that ended up being more work than I wanted.
Punteggio 0
1 Commento:
did you ever figure this out?
da
There are some videos on YouTube that show how to take apart a Theragun. Removing panels on a Theragun to repair a Theragun (Fixing a Theragun)
Punteggio 0
The two battery packs for my Theragun Pro Gen 4 wouldn't charge so I opened the charging dock to take some measurements and found a burned resistor.
From the dimensions and code on the chip, it was a 100 ohm , 1/4 watt surtace mount device.
I replaced it with a 1/4 watt axial resistor and the dock was able to charge both my packs.
(I had to solder tack wires to other points of the board since the surface mount pads were damaged by the overheating.
I used a meter to trace where else I could attach the new resistor.
One end of the resistor went to a cap pad.
and the other end went to a diode pad)
Punteggio 0
3 Commenti:
From the photos in an earlier post on a 3-cell battery and dock, I can see that a smaller 1/8 watt surface mount resistor was originally used on the board. I suspect they needed to increase the wattage to handle a 4-cell battery pack and since the larger device would not fit on the existing circuit board pads, they tack soldered the larger resistor in place at an angle, and also milled away part of the case so it would fit. There was a cold solder joint that probably had high resistance and the resistor overheated and failed.
da
I am a Theragun Pro Gen 4 user from S. Korea. I've also experienced the same symptoms. I've shared the photos below.
da
@davidiwatsuki Their internal electrical design is really mediocre, to say the least
da
At one point, the battery wouldn't charge, so I replaced the adapter and measured the 0 voltage at the charging dock's terminal with a multimeter.
The adapter supplied the same output voltage (approximately 15-16 V). So, I initially suspected a bad contact with the latch.
(bottom part)
Disassembling the battery is extremely difficult.
There are assembly lines on side, but they appear to be laser-deposited.
I managed to disassemble it with a grinder. Only try this as a last method if there's no problem with the dock.
(upper part)
The lack of light on the charging dock is a sign of a circuit malfunction.
As previously explained, there are signs of burnt circuit boards.
The affected components need to be replaced but the circuit board is burnt, a bypass line must be found.
Furthermore, in my case, the front MLCC was also damaged.
I haven't been able to do a complete repair yet because I'm still looking for parts.
Punteggio 0
1 Commento:
Wow! you look at the photo I posted earlier, the capacitor at the front has the same burn marks around the pads. I think it was sloppy rework soldering rather than any any physical damage since it looks like they were trying to solder a through hole component onto surface mount pads.
da
Theragun Elite, no replaceable battery.
Took apart by prying off the covers. The right side is the side to pry off. Then pry off the rubber where the display is. I broke mine rubber part.
Next undo all the screws. There should be 13 in total, two silver and the rest black.
At this point you can pry it open enough to remove the battery pack.
Remove the wrap from the battery pack where the PCB is. This is the thinner part. Remove the rubbery material as well over the PCB.
Next using a digital multimeter (DMM) measure each battery (positive first, negative second)
  1. B1 to B- (tab the battery connects to the PCB)
  2. B2 to B1
  3. B+ (tab the double stacked battery connect to the PCB) to B2
All should be above 2.5V. Mine where the following.
  1. 1.4V
  2. 2.5V
  3. 2.5V
I believe the PCB uses the bottom most cell (1) for the electronics when turned off, so it will drain lower than 2.5V. The safety circuit, if I recall correctly from previous medical devices I designed will not charge if the battery terminal voltages are below 2.5V.
To resolve my issue I set my bench top power supply to 3.6V and limited the current to 300mA. I touched the leads to B1 (positive) and B- (negative). In my opinion you DO NOT want to give it anything higher than 4.2V, so another single lithium ion battery would work, or even two AA in series. The goal is to get the voltage above 2.5V. I see a picture of a 9V battery (really just 6 x AAAA) and another poster said a ryobi 18V! Definitely not recommended as over voltage stress is real....
As I did this I watched the bench top power supply voltage tick up as energy was put into the battery. At 3V I stopped and measured the voltage with the DMM again. I then plugged it and the display said 10%, previously when I plugged it in it would say 0%.
At 23% I unplugged the AC/DC adapter and turned it on. It worked! right now the voltages are:
  1. 3.568
  2. 3.556
  3. 3.559
They are all close to one another which is good. Unplugging the charger I get the following:
  1. 3.508
  2. 3.497
  3. 3.486
These are balanced enough, so the cells seem to be good. If one was lower than the rest (difference more than 0.100V), I would scrap the Theragun Elite and not bother wasting more time on it. I enjoy fixing things, but I have to draw the line at 2 hours maximum.
Punteggio 0
Aggiungi la tua risposta
STSTom sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 37
Ultimi 7 Giorni: 247
Ultimi 30 Giorni: 1,302
Tutti i Tempi: 36,287
