Salta al contenuto principale
Fourth generation Samsung Android tablets. Released in April 2014.
355 Domande Visualizza tutte
Tablet charger port broke I dont want to buy the charging port
my tablets charcging port broke badly i removed charging port from th flexible wire and tried to charge the battery by opening the back cover and charging it directly,The battery is full but when i power on no response i hold the power button and volume then also no response not even vibration,I even checked all the thin flexible wires that they are connect or not, found every single wire is connected properly its like dead so........can anyone say whats the problem??????????????????????????????
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
When you say the charging port, do you mean the actual port in the device or the charging cable?
How did you charge the battery directly?
Punteggio 1
7 Commenti:
not charging cable
thanks for reply
da
the charging port i am talking about
flexible wire means the thin wire it flexible and golden colour
da
Great, thank you. How did you charge the battery directly? What did you do to charge it?
da
directly.I cut the charging cable and
took positive and negetive and charged it i saw a youtube totorial
da
Can you say why it's not turning on
da
Mostra altri 2 commenti
Aggiungi la tua risposta
zolocoster17 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 52
