Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
3 Commenti:
This is one of those jobs where the pictures aren’t high enough quality I’m afraid. Also one where a microscope is really needed. I see one trace going to the vias plus what looks like a burn between the two. also if it’s a multi layer board then more connections could be shorted or damaged. Something has blown causing that damage. It’s possible it might be un repairable.
da [deleted]
@hasbanshakil consider cleaning your board of all the soldier and burn residue. Then repost some good clear straight-on pictures of the damaged area.
da oldturkey03
Can you make me an alternate of its print lines like jumpers
da Hasban ur Rehman
