Salta al contenuto principale
The sixth generation of Ford's Falcon line, including the AU, BA and BF series.
5 Domande Visualizza tutte
Where is oil leak from
How to find where oil leaking from engine is
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Use a flashlight to check underneath your car and around your engine – telltale drips might lead you right to the problem. There are several common locations for oil leaks in your car, including: At your oil pan gasket. At your oil filter or drain plug
Punteggio 0
Aggiungi la tua risposta
rob hutchings sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 223
