Salta al contenuto principale
Annunciato il 13 ottobre, l'iPhone 12 Mini è una versione più piccola dell'iPhone 12 di Apple. Si caratterizza per lo schermo OLED da 5,4", processore A14 bionic e per la doppia fotocamera posteriore
iPhone 12 mini black screen
i have an iphone 12 mini the screen is black. However when i place it on a wireless charger it gives a charging beep but the screen remain black. What could be the problem? is it the screen or the battery not charging??
Questa è una buona domanda?
Punteggio 1
4 Commenti
It probably died and you have to get a new one.
da
thank you. U mean new battery not new phone?
da
New batterys
da
And if that doesn't work you might have to buy a new phone.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
@sirneilsirneil try seeing if it will connect to itunes, it could possibly be in dfu mode
Punteggio 1
I'm going to disagree with @liljk; there's nothing to indicate a bad battery at this point. The fact that you get a normal reaction when setting it on a wireless charger says that the phone is running. I'd want to do some investigation first, but in situations like you're describing it's generally a screen problem.
First thing to do is try plugging it into a computer and see if it's recognized. If possible, try doing a full restore of the phone's firmware to try and rule out the possibility that it's a software issue rather than hardware.
Worst case in my opinion is you have to replace the screen. Here's the iFixit guide do to that.
Sostituzione schermo iPhone 12 Mini
Punteggio 1
Aggiungi la tua risposta
Sir Neil (Sirneil) sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 370
