Salta al contenuto principale
Il Samsung Galaxy S8+ è la versione maggiorata del telefono al top di gamma Samsung. Lanciato nell'aprile 2017.
WhatsApp calls with Bluetooth headset
When I'm using a Bluetooth Headset and I make a WhatsApp call, my friend will stop hearing me as soon as the screen of my phone goes on standby. Have you experienced that before and what can I do.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Set the screen to either stay on longer or not turn off. Be warned, depending on phone you could be causing screen burn by doing it. When the screen goes off it basically closes the app, ending the call so to speak. There may be something in permissions you can change.
Punteggio 2
1 Commento:
Thank you for your response, that is what i currently do, however, you should note that this is not good for the battery and it can also burn the screen. I will appreciate if anyone knows the permission that can be activated or changed.
Thank you Nigel
da
Aggiungi la tua risposta
Kunle Olagunju sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 143
