MBP shuts off without power adapter. Battery has 5 charge cycles
I have a 2014 macbook pro that got to the point that it needed to be plugged in all the time, and also the keyboard and the trackpad were broken. I bought a replacement upper case from ifixit with a keyboard, trackpad and a battery already installed.
After installing the new top case assembly, I did the recommended battery calibration (full charge, use until empty, full charge) and everything seemed great until about 2 cycles later. I noticed that it was only charging to about 75%.
I reset the SMC, and tried draining and fully charging the battery. Again it stopped around 75% and now, when unplugged it dies after about 2 seconds (not instantly). I tried booting unplugged. It almost fully boots then shuts off. Over the last 3 days the charge percentage has crept up to 88%, but still dies when unplugged
ifixit has offered a replacement battery or a return/refund, but I'm wondering if it could be something else.
Update: Disconnected battery, booted and powered off, reconnected battery, still not fully charging or running off battery.
Update (03/20/23)
Weird update to the original post:
I did discover that I do have a knockoff charger. 2 years ago I unknowingly bought an amazon clone/fake. I watched some comparison videos and am pretty certain it's not a genuine Apple.
BUT, after a two weeks of the macbook shutting off any time the power was disconnected, it started working normally again. I've been running it alternatively off of the power adapter and battery for two days with no problems. It's currently charging at 62w. So we'll see. It's days are likely numbered. But maybe it's a software issue?
Questa è una buona domanda?
@cg4n6 - if the real Apple charger is working you are very lucky!
Get rid of the knockoff as you just don’t want to use it again.
There is no software issue here, just a confused SMC logic.
Resetting it like we did is all that was needed. You should be fine!
Don’t forget to score the answer and accept it if you’re set - Thanks!
da Dan
