Salta al contenuto principale
Can I put a SSD in it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Yes. Just remember the PS3 cannot address drives larger than 1 TB.
Punteggio 3
You can get SATA adapters to install standard HDDs and SSDs into the expansion slot so it is possible but I cannot see why. The hardware is slow enough that it couldn’t utilize the speeds of an SSD in any noticeable way. A standard hard drive would work just as good for much cheaper.
Punteggio 2
1 Commento:
Ok, thanks. Just wanted to know if would work and what the differences would be.
da
Aggiungi la tua risposta
NR26 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 173
