Salta al contenuto principale
Model M4753 / 233, 250, 266, 292, or 300 MHz G3 processor
Where could I find the correct charging cord for this PowerBook?
I have this PowerBook G3 Wallstreet and I have not been able to find a changing cord for it. Everywhere I look I only see things for only an iBook or newer PowerBook. I bought an iBook charger a little while ago and it worked with my iBook but I found out then that there were two different sizes of changing cords and that the one I got for my iBook did not work with my PowerBook. What cord size would be correct for this PowerBook and where would I be able to find one?
Thanks,
Derek
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It sounds like you're looking for a charging cord for your PowerBook G3 Wallstreet and have had trouble finding the correct size. The PowerBook G3 Wallstreet uses a unique charging cord with a barrel plug size of 7.7mm x 2.5mm.
You can find replacement charging cords for the PowerBook G3 Wallstreet online from various retailers such as Amazon or eBay. When searching for a replacement cord, make sure to check the specifications and ensure that the barrel plug size is 7.7mm x 2.5mm to ensure compatibility with your PowerBook.
Alternatively, you may also want to check with local electronics or computer stores to see if they carry a compatible charging cord.
Punteggio 1
3 Commenti:
Thank you for your response Jelly Bean man,
I have been looking on Amazon and have had no luck there. I looked at eBay as well and the listings there look promising. It is very hard to find the specific charger I am looking for because it is so specific and old. It looks like iBooks and PowerBooks before 2000 used this specific size of charger I am looking for. Thanks for your help!
da
@Derek Thomas no problem happy to have helped you
da
Sure, here are some links that might be helpful:
PowerbookMedic: https://www.powerbookmedic.com/
Macofalltrades: https://www.macofalltrades.com/
OWC: https://eshop.macsales.com/
iGo charger: https://www.amazon.com/iGo-Power-Tip-70-...
Targus charger: https://us.targus.com/products/laptop-ch...
Lind Electronics charger: https://www.lindelectronics.com/collecti...
MacRumors forums: https://forums.macrumors.com/forums/powe...
Please note that I am not affiliated with any of these websites and cannot vouch for the quality or reliability of their products or services.
da
Aggiungi la tua risposta
Derek Thomas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 35
Tutti i Tempi: 360
