Why wont my doors open?
1993 Caddy Deville. Front passenger and rear driver side doors will not open. They act like they are locked but they are not. Tried using key, remote on key fob, and manually from inside. NONE OF THOSE WORKED. How do l get the doors open without using a sledge hammer?
Questa è una buona domanda?
The latch mechanisms in the door sound like they could be rusted or stuck.You could try installing a wood shim between the window and the window seal. It'll make it easier to spray a penetrating spray to get the latch moving again
da Kuromi
Hmmm...will try that, thanks! I've already used a whole can of WD on them, but didn't use a shim. If rust is the issue, would the door work smoothly one second and not at all the next?
da Angie Holley
