It wont turn on and when I plug it in it does not even show the bat...
It won't turn on and when I plug it in it does not even show the battery percentage screen?
Questa è una buona domanda?
@nytryder26 how old is your battery? An old depleted battery can prevent your phone from coming on. If it is relatively new, or if you have checked it properly and it is still working, you will have to check the charging port. Disassemble your phone and measure the contacts of the port on the board side. See if it even makes contact. Use something like this video to get into your phone to check things out.
Slightly different model, but same unresponsive with a possible solution on here
Ok thanks, Ill check it out!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 64
