Salta al contenuto principale
The GoPro Hero5 Black is an HD waterproof action camera released by GoPro in October of 2016. The 4k resolution video camera has voice control, a touch screen display, and built in WiFi.
Will not detect or read and SD card
It just keeps reading SD card error
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi
Sometimes cleaning the SD card slot with some isopropyl alcohol and a toothbrush can help to resolve this issue
Also the Hero 5 was known for the water resistance being a bit of a hit or a miss so if it has been exposed to water I would recommend using this guide to check the device for water damage
Here’s a disassembly guide
GoPro Hero5 Black Motherboard Replacement
Once again isopropyl alcohol is good at cleaning corrosion but water damage can sometimes need professional work
I would also check the formatting of the SD Card,make sure the GoPro can read it:-)
Hopefully this helps
Any questions please ask
Punteggio 1
1 Commento:
Try another SD card before you get to the point of disassembly, i've had some SD cards fail in odd ways like that before!
da
Aggiungi la tua risposta
tourette88 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 321
