Salta al contenuto principale
Support for the third generation of Chrysler Town & Country spanning model years 1996-2000.
No power to radio, windows, wipers
I have a 1999 dodge caravan sport and it just recently started to have a problem. When I crack the van up it sounds like a small pop sound under the dash and I have no power to the wipers, windows, and radio, and the air then switches to the defrost automatically. However, when I turn the van engine off the accessories then come back to life, but they go back out again when I start the motor.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I immediately suspect a bad ground. Most vehicles have a grounding block that will commonly ground many accessories. It will usually have a metal strap looking cable coming off of it that connected to the motor, trans or frame.
Hopefully someone here can tell you where to find the grounding straps on a 99 caravan. Unfortunately I have no idea.
Punteggio 0
Aggiungi la tua risposta
Robert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 268
