Salta al contenuto principale
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
Suddenly no sound, everything else looks normal
This morning I went to use my Wave as usual. After about 5 seconds the sound cut and I can’t get it to come back. Everything else looks and functions as normal. Any ideas what component suddenly died and how to fix it? Bose are no help … thanks!
Questa è una buona domanda?
Punteggio 0
4 Commenti:
@bmort time to take it apart and see what may have failed. Look for components that may have overheated, corroded or otherwise look damaged. Of course, make sure that all your "external stuff" like volume, connections etc is all still properly connected and set Bose Wave Radio AWR1RG
da
Yes I'll take a look inside to see if anything is visually damaged. I've heard the battery can leak onto some important wires over time. If that's the cause of the failure I wish they'd not bothered to put a battery in the first place...
da
My awr1-1w won't make any sound at all.
da
My awr1-1w doesn't make any sound not even the static for the radio what could be the problem?
da
Aggiungi un commento
1 Risposta
I think it's problem of thermal shut down by amplifiers chip
Keep in air circulated space amd try
Punteggio 0
1 Commento:
It's currently about 12 degrees celsius in the room where we use this and nothing over the vents so think that temperature shouldn't be an issue :)
da
Aggiungi la tua risposta
Ben sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 15
Ultimi 30 giorni: 55
Tutti i Tempi: 1,119
