Salta al contenuto principale
Guide e informazioni per la riparazione dei controller Joy-Con di Nintendo Switch.
My right joycon is not recognized horizontally
Hi,
Both of my right joycons cannot be used horizontally AND their sync light does not work. They do work fine when used vertically (either docked or wireless), but just cannot be used horizontally. Any idea what I could do?
Thank you!
Laurent
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
It could be that a connection is loose inside of the controller. The accelerometer might also have a short causing it to short when turned on it’s side. I hope that will help you. 🙃
Punteggio 1
2 Commenti:
Thanks! I've ordered a screwdriver to try and clean the connection, and possibly check if anything got loose.
da
So when i open the controller and use some contact cleaner, it partially works, from time to time. But not when it's close. So some connection is loose. Both controllers that have this issue are right controllers and still charge. I'm trying to figure out what exactly couod be wrong.
da
Aggiungi la tua risposta
Laurent sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 50
Tutti i Tempi: 1,779
