1993 Buick regal custom want crank
Why my 1993 Buick regal custom want crank anymore..? It ran hot on me to the point the car automatically shut off while driving so I had to pull over let it cool den added water, stem was every where even smoking from the back of motor near passenger windshield after I put water into the car I tried cranking it and now it want crank it turns over but still will not crank and it has gas in the car......
Questa è una buona domanda?
Punteggio
0
Can you test for spark and fuel? Two people needed; one to observe spark from at least one plug (plug base grounded to engine block, plug wire connected to plug as the other person turns ignition to START). If a fuel test valve is available (usually on the fuel rail), depress the valve stem with a rag loosely covering it with ignition to see if fuel sprays out.
da F Dryer
