Salta al contenuto principale
Model A1138 / 1440x960 screen resolution
85 Domande Visualizza tutte
Immediate shut down independent of battery charge
Hello
My PB shuts down immediately most of the times when the battery is empty or even when it is fully charged. Sometimes I lose my work and the Date and Time, but not always.
The last time the battery has been fully charged and is indicating that it is.
Best regards
Klaus-Dieter
Questa è una buona domanda?
Punteggio -1
3 Commenti
Does this happen when your computer is plugged in to power too?
da
This morning I selected Sleeping in the menu and the PB shuts down immediately, even the hard drive had no time to position. After Reboot I have lost all my settings, Date, Time and Keyboard Layout.
I have to tell since I used Monolingual I have several problems with software and I do not know if this could be a problem of the removing of Intel code.
Best regards
Klaus-Dieter
da
No, it only happens when the power plug is not connected.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The loss of date and time are coming from a dead PRAM battery that stores this information. Replace it first and then see if your other problems persist, here's the part: [prodotto collegato mancante o disabilitato: IF154-094]
Punteggio 3
2 Commenti:
Thank you very much. I have already ordered it, but it will take time to be delivered.
I will tell you if it works and will set a score if it fixes the problem.
Best regards
Klaus-Dieter
da
Aggiungi la tua risposta
MacWiniac sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 582
