Salta al contenuto principale
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
20 Domande Visualizza tutte
Is possible to upgrade build in fan to a Noctua one?
My second hand Thunderbolt Display easily getting hot, I can't sure is the fan works or not.(But when the environment is quite, I can heard "bo bo bo" sounds.) Can I replace the fan which has higher RPM with same voltage?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sorry Apple uses a custom fan unit. It’s likely the fan is either damaged (out of balance) or loaded up with junk.
Given the age I would start off just cleaning out the dust and debris that’s collected inside. I’ve found stapes and small scraps o paper mess up the fans in system
I find a small soft paint brush and a can of can’d air will do the job!
Here’s one source for the needed fan 27" Thunderbolt Display Fan - Apple P/N 922-9936
Punteggio 3
Aggiungi la tua risposta
imjeremysome sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 69
