Why is my fan not running?
power supply has good 12vdc. replaced fan and new fan is not starting either. any suggestions? is there another part that could cause the fan to not run?
Update (03/16/23)
ok, am thinking that the fan is not the issue then.
thought it was a heat issue because when it stops and try to turn on it will not stay on.
timer or board issue??
Questa è una buona domanda?
1 Commento
Does the new fan have the same spec's (ie, not 24V or 240VAC or 120VAC)? Can you run both fans on a 12V battery? The power supply may have the correct voltage, but fail to supply enough current or more likely, detect an over-current condition and refuse to run your fan or any fan. Some fans have 3 wires, some 2, others are a four-wire job. Try running a dummy load of same rating to confirm this.
da Barrie
