Salta al contenuto principale
Supposedly "new" projector, LAMP warning, no image
Hi! I just unboxed a supposedly "new" Amazon-bought projector, a new box, all manuals and cables present, in a pristine state, and even a brand-new smell. It turned on dimly for a few seconds, then the LAMP light came on and the unit did not turn on again. Fan spins and the beep starting tone is heard. Took the cover off, projector looks completely new. Took the lamp out, completely new, with no heat marks, and measured resistance between terminals: zero ohms. No smells or signs of use inside the projector.
I have intermediate electronics knowledge, but no projector experience. Is there any other thing I can try, for example, a way to test the lamp ballast output?
Thank you
PS: The projector is outside of the returning window time.
PS: Tried connecting an RS-232 cable, but there is no response. Doesn't matter too much, because there is no command to reset the lamp counter or do something useful for my problem.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Well, I'll share with you the things I found out:
1) There's no way to test the lamp with a multimeter. Some good lamps appear open, others zero resistance. Only test with a known-good lamp.
2) To repair the ballast, follow this guideto test and replace the MOSFETS as required (I'm not affiliated with it on any way, just found it on Youtube)
https://www.youtube.com/watch?v=zcYFiew2...
Punteggio 2
Aggiungi la tua risposta
Luis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 158
