Salta al contenuto principale
Processore dual core Intel Core i5 da 2,5 GHz (3,1 GHz con Turbo Boost) con 3 MB di cache L3.
Which SSD enclosure works best with this model?
I recently just bought this enclosure. External M.2 SSD NVMe Enclosure Im wondering if this is compatible with my MacBook Pro 2012 so i can get the data off of it or which enclosure i would need to get this working. Thank you.
Update (02/04/2023)
Unsure if my wording is wrong but the SSD i have is from a MacBook Pro 2012 retina. I’m trying to get the data off of it And Im wondering if this enclosure will help me do that once i plug into a new MacBook.
Immagine Use an M.2 SSD as an external drive in this enclosure. USB 3.1 transfer speeds up to 10GB/s
Prodotto
$29.99
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Unfortunately That one won't work due to apple using their own Proprietary SSD Connector.
But OWC has one!
Part: OWC Envoy Pro External SSD Enclosure (Mid 2012 and Early 2013 Macs)
Immagine Make your factory installed Apple SSD into an external SSD drive. Transfer data to a newly installed internal SSD or keep the original drive as added external storage.
Prodotto
$69.99
Punteggio 1
Aggiungi la tua risposta
dayronh3 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 210
