Salta al contenuto principale
Repair guides and information for Microsoft's Surface Pro line of 2-in-1 tablets.
20 Domande Visualizza tutte
How do I identify my specific model of Surface Pro?
How do I identify my specific model of Surface Pro? I tried the System Information but it says only Surface Pro. Under System SKU it shows Surface_Pro_1796. I need to replace the battery and want to order the right one, the first time.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hello, if you put your serial number in this link -> Check Warranty Page - ROBO SelfServe Portal (surface.com)
It should come back with the exact model.
To find your serial number you can use this microsoft guide -> https://support.microsoft.com/en-us/help...
Punteggio 5
1 Commento:
Thanks for the response. I found the serial number in the Surface app on the device, it's a Surface Pro 5th Gen which I also found out is AKA Surface Pro 5. Thanks again for the quick response, now I know which battery to order.
da
Thank you
The link works fine
Punteggio 0
Aggiungi la tua risposta
Keith Ball sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 25
Ultimi 7 Giorni: 170
Ultimi 30 Giorni: 795
Tutti i Tempi: 34,367
