Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
iPhone Reboots after 2 minutes
I have recently fixed a water damaged iphone 3GS by replacing the dock connector, the battery and the lcd screen.
Initially, for about 4 weeks it was working fine with out any issues at all.
Last week it suddenly started resetting when it was charging.
Thinking it would be a software issue, I did a full restore but got the error 29 issue. I looked up possible issues, and ended up getting another new battery. This was worse than before and it would refuse to connect to the pc long enough to restore.
I then ordered another new battery, this time with an early part number, and it was fine for 24 hours, until it needed to be charged, Now it will boot fine, then after 2-5 minutes it will just reset completely.
I have tried airplane mode, and it seems to last a little longer before restarting, but this might be a red herring.
I don't have the original battery so I can't check the part number.
Also, could this be caused by a faulty dock?
Thanks.
Questa è una buona domanda?
Punteggio 1
3 Commenti
does clock/date reset or is it just reboots?
da
It just reboots. Clock appears the same. Screen goes blank, apple logo then back to the home screen.
da
Seems to only do this when fully charged, When it gets to a 50% charge or so, its fine. Weird.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
FIXED! This is related to the proximity sensor. Found a post on a blog (http://phonebatterylife.com/blog/iphone-...) that states it would be this, Tried it and it works fine again!!!! I would recommend others with a similar issue try disconnecting connector 3 and see if it resolves the issue.
Punteggio 3
Hello, you can try to fix this by entering your iPhone into recovery mode. This is the best way to enter and exit iPhone recovery mode. Have a try if needed. Totally free and safe tool.
Punteggio 0
Aggiungi la tua risposta
Joel B sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,462
