Salta al contenuto principale
Repair guides and support for a wide range of snow blowers.
Cannot remove shear pin from EGO snow blower axle.
Have pounded very hard on the pin, brought blower in house to warm it up but still can't remove sheared pin
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Try heating up around the pin, not the pin itself. If any of the pin is sticking out, then put a piece of ice on it, and try hammering it out again. You want the pin cold as you can get it while heating the metal around it. This will cause the metal holding it to expand and loosen its hold. Wd40 also works, if you give it time to penetrate
Punteggio 1
Aggiungi la tua risposta
Maurice Blais sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 448
