Salta al contenuto principale
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203 Domande Visualizza tutte
Replacement Internal Screw Sizes
Does anyone know the sizes of the screws used internally? Several of mine stripped after using the wrong bit and I would like to replace them. I know there are replacement screw kits you can buy but they seem way overpriced.
I attempted to measure with my calipers but my measurements did not match common sizes. For example, the motherboard mounting screws measured at 1.33mm in diameter which is half way between the (what seems to be) standard M1.2 and M1.4.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
The 3DS XL and the 2DS XL use the same screws. You can easilly buy a screw kit for a 3DS XL for 5 bucks. Hope this helps.
Punteggio 1
2 Commenti:
Do you happen to know the screw sizes for the 3DS XL?
This would be good information to have as I have not found it documented anywhere. Plus, for $5 one can buy 100s of screws.
da
https://www.ebay.com/itm/184217821814 5 bucks is 5 bucks. Just take the easy route
da
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 36
Tutti i Tempi: 612
