How do I fix a broken stick piece on the Switch ProCon?
I was finished changing Pro Controller shells until I found the right stick feeling crunchy when I clicked it. After clicking, the stick would often get stuck on the right side, and when I opened the controller again, I found this part popping out when the stick was pressed. If this is part of the problem, how can I go about fixing it?
Questa è una buona domanda?
You probably caught it and pulled it out assembling it. Unless there’s damage you should be able to push it back into place until it clicks. As @tomchai says, you may need a new module fitted.
da [deleted]
