How do I get this working after replacing internal battery?
I replaced the internal battery, but company won’t send updated software. I don’t care about recording data—just want the thing to work
Questa è una buona domanda?
Replacing the battery alone doesn’t seem to solve the Fault 33 error (which technically is an over pressure warning). I’m looking at replacing the transducer and will report on the results in the CPAP forum. It’s been reported that pushing a pin into the transducer eliminates the fault, I suspect it might also eliminate the unit from accurately monitoring set pressure. This would render it no longer safe for their intended purpose.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 37
Tutti i Tempi: 404
How to replace internal battery?
da DENNIS PRAMAS
So it won't work after you replaced the battery?
Are you sure it's a software issue?
da Hampter
