Salta al contenuto principale
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412 Domande Visualizza tutte
My 3DS is Not Switching On And Is Only Charging For 1 Minute.
Heya, so basically I was on a trip and I left my 3DS XL in my pocket in sleep mode for the whole day. By the time I took it out, the battery was dead. I received this 3DS from my cousin in the U.S. and I couldn’t use the original charger because in Indian sockets, the voltage is very high and my cousin plugged it into one and now, the original charger doesn’t work. So I bought another USB 3DS cable to charge from Amazon and it worked perfectly for 5 months. So back to the trip…we went to someone’s house and I forgot to bring my adaptor( I only got a cable and no adaptor was attached to it as it is in the original one )so I just saw one In their house and plugged it into a socket. The orange charging light didn’t light up which was weird so I took it out and tried a different socket. Here it worked and I just left it there. Later when we were leaving, I went to get it and the light wasn’t there so I thought it was fully charged. When we reached back home, I thought I’d just finish one more level in Super Mario 3D Land. When I pressed the power button, no blue light lit up and the device didn’t boot up. After trying many times, I remembered when It didn’t charge at the house. I started panicking and put it for charge and set a stopwatch and watched. As soon as the timer hit one minute, the light went out and I confirmed this by trying it about 3 more times. My dad said it was probably bricked cos I plugged it into an adaptor I knew nothing about. When I asked on Reddit, they said don’t use a fast-charge adaptor cos That could brick the console. As of now, I still know nothing about the adaptor, I’m not sure why it isn’t working, etc.so here are the main points:
  1. When I press the power button, it doesn’t boot up and the blue light doesn’t light up.
  2. When I put it for charge, the orange light stays for 1 minute, no more, no less and then stops. I don’t know why…
  3. I used it with an adaptor I know nothing about which probably caused this but I’m not sure.
  4. I opened the back and had a look at the battery which didn’t look like it had anything wrong with it.
  5. I can’t buy a new battery cos it’s really expensive in India because Nintendo doesn’t operate here.
What do I DO? Please help me…I really miss that blue light… Heya, so basically I was on a trip and I left my 3DS XL in my pocket in sleep mode for the whole day. By the time I took it out, the battery was dead. I received this 3DS from my cousin in the U.S. and I couldn’t use the original charger because in Indian sockets, the voltage is very high and my cousin plugged it into one and now, the original charger doesn’t work. So I bought another USB 3DS cable to charge from Amazon and it worked perfectly for 5 months. So back to the trip…we went to someone’s house and I forgot to bring my adaptor( I only got a cable and no adaptor was attached to it as it is in the original one )so I just saw one In their house and plugged it into a socket. The orange charging light didn’t light up which was weird so I took it out and tried a different socket. Here it worked and I just left it there. Later when we were leaving, I went to get it and the light wasn’t there so I thought it was fully charged. When we reached back home, I thought I’d just finish one more level in Super Mario 3D Land. When I pressed the power button, no blue light lit up and the device didn’t boot up. After trying many times, I remembered when It didn’t charge at the house. I started panicking and put it for charge and set a stopwatch and watched. As soon as the timer hit one minute, the light went out and I confirmed this by trying it about 3 more times. My dad said it was probably bricked cos I plugged it into an adaptor I knew nothing about. When I asked on Reddit, they said don’t use a fast-charge adaptor cos That could brick the console. As of now, I still know nothing about the adaptor, I’m not sure why it isn’t working, etc.so here are the main points:
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
replace the battery this should solve your problem
Punteggio 0
1 Commento:
Yea but 3DS batteries don't come cheap here as Nintendo doesn't operate in India. It's probably like 45 dollars in USD for one battery😶
da
Aggiungi la tua risposta
Joel Titus sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 131
