Salta al contenuto principale
Guide e informazioni per la riparazione dei controller Joy-Con di Nintendo Switch.
167 Domande Visualizza tutte
joy-con glitches when used wirelessly for around 45 mins
so i replaced the casing on two joy-cons about a month ago and a week ago I noticed that the right one would glitch when it was in TV mode for around 45 mins and would completely die for 5 mins before reconnecting to the switch, it works fine in handheld mode, but glitches in TV mode and handheld mode.
so uh edit-
it kinda dies for 5 mins still but now you have put the switch in handheld mode and then take the joycon back off for it to be able to be used wirelessly again.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Check your connections between the battery. That is usually the culprit.
Punteggio 1
Aggiungi la tua risposta
timtom77 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 26
