Salta al contenuto principale
Una Pathfinder riprogettata è stata messa in vendita a fine ottobre 2012 come modello del 2013. Proprio come la seconda generazione di Pathfinder, si è allontanata ancora una volta da un SUV basato su telaio a longheroni (body-on-frame) e ha adottato un design unibody.
Passenger door handle cord snapped
Does anyone know how to replace the cable for the passenger door so that I can open it from the inside again it appears like a cable is snapped and I don’t really know how to get in there and replace it myself
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
This is a relatively common issue on the forth gen Pathfinder, it's less likely that the cable snapped and more likely that it disconnected from the handle, the point of failure is a C shaped bracket on the interior of the door handle, if that is in fact the issue, the handle assembly will need to be replaced (they're relatively cheap, thankfully).
The process of actually getting to it is slightly more involved.
This is the most accurate video I've seen (some don't show the cable at all) https://youtu.be/B19u9ADWFdw
As a sidenote, it can technically be done without disconecting the control panel, but I wouldn't recommend it.
Hope this helps!
Coco,
Punteggio 1
1 Commento:
Had this issue, ordered replacement handle. Everything going well, then I realize the bottom cable with a metal ball on the end is missing the ball. Like it snapped off.
Any thoughts on repairing or replacing that cable?
da
Aggiungi la tua risposta
Rachel sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 35
Tutti i Tempi: 946
