Salta al contenuto principale
Guide di riparazione e informazioni sullo smontaggio per il MacBook Pro 16" uscito a novembre 2019. Modello A2141, EMC 3347.
Is this a GPU problem or a display issue?
Immagine
I was watching Youtube when this started happening.
It's had some weird graphics issues in the past (horizontal green lines), but this seems different. Is this a GPU issue or a display issue?
Questa è una buona domanda?
Punteggio 2
1 Commento
Did you bang the hinge area or get something caught on the upper case when you closed the lid like a paperclip or other object near the hinge area?
Sadly, this is an expensive repair as the part alone is around $800
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
My initial thought is display. Especially based on the bands of "normal" in between. These stripes almost certainly align with the cabling inside the display.
You can see what I mean a bit in this photo from a 13" model with the bottom bezel (where the MacBook Pro branding is) removed.
Immagine
The best way to know for sure is to connect it to an external display. Normal video out is a dead ringer for it's a display issue.
Punteggio 4
Aggiungi la tua risposta
Addison Moore sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 30
Tutti i Tempi: 1,016
