Salta al contenuto principale
The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
47 Domande Visualizza tutte
Is it dangerous to turn on a eMac that hasn't been used in 5+ years?
Hi,
Just found a emac and is wondering if I should take any percautions before starting it up to see if it works.
Update (01/09/2023)
Sorry to bother again but I realized that the eMac is stored glass down with no towels. Is it still ok?
Sorry I'm just afraid as I don't want any damage to happen to it.
Thanks so much :)
Questa è una buona domanda?
Punteggio 1
1 Commento
Thanks so much :)
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@appleipodnano the only thing for now is checking the power cord. Make sure that it is not frayed or cracked due to age or weathering. Out of habit, I stand to the side of the equipment to check it and when I turn it on. Just old habits from some "interesting" devices I 've worked on. Otherwise, give it a try and let's see if it'll fire right up :-) Let us know if it turned on....
Update (01/09/2023)
@appleipodnano just in case you actually would like to troubleshoot or consider working on it you may want to look through these guides. The ESD safety Guide will be of particular interest to your personal safety ;-) EMacESD Safety Technician Safety We would need to know the exact model for your eMac to be more specific for the service guide. Enjoy it.
Update (01/09/2023)
@appleipodnano no problem. Yes, you should be okay. Of course, it all will depend on where it was stored. Any chance it may have gotten liquid into it? If unsure, then I would do it a bit different. Use the guide I've attached and just remove the rear housing. Then see what you are up against. Any corrosion, frayed wires anything, then wait and repair that stuff first. Post a couple of pictures with your QUESTION so we can see what you see. At this time you do not have to worry about the ESD safety etc since the device hasn't been plugged in for a long time. Of course, it is always good practice to not unnecessarily touching exposed wires or components, but you are safe on a piece that was unplugged for a long time. By now, it will be totally discharged.
Congratulations on being careful and conscientious. All good traits to have, to get things fixed right!
Aggiungere immagini ad una domanda
Punteggio 2
2 Commenti:
Tanks so much! I will try it soon :)
da
Where it is stored it is near impossible to get wet. I think im ok :)
da
Risposta Più Utile
Well … It’s safe to plug in to see if it works. But if you open it up you do need to be careful as you have some large capacitors and the CRT also holds a sizable charge. Each could hurt you or worse!
Punteggio 2
1 Commento:
Yeah I don't plan on opening it, as I read the other question about CRTs.
da
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 92
