Salta al contenuto principale
The N200 5G is a OnePlus entry-level phone. It sports a 6.49” (1080 x 2400) screen at a 90hz refresh rate, 64 GB of internal storage, expandable storage up to 256 GB, and 4 GB of RAM.
How do I replace just the front glass?
Out of all the videos I've seen, most just get a full lcd replacement. I don't want to replace that, I just want to replace the screen glass.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi Lily,
The problem here is that the LCD and front glass are bonded together with a glue called OCA, or Optically Clear Adhesive. It generally requires specialized tools, equipment and experience to separate them successfully, and then rebond the new glass to the old LCD. In almost all cases it's not worth the time and effort it takes to do that; in order to make sure you don't get bubbles in the glue you need to cure it in a vacuum chamber, which most of us don't have at home.
Since the replacement display sells for under $25 USD on AliExpress, it's really not worth your time to mess with separating the glass, cleaning the LCD, ordering the correct OCA and then trying to get it reglued without bubbles. I strongly recommend you just bite the bullet and replace the whole thing.
Punteggio 3
Mi pantalla está roto
Punteggio 0
2 Commenti:
For those of us who don't speak Spanish, Google says this means:
My screen is broken
da
Hi Yanick,
Assuming you're coming here for help in repairing your screen, even though iFixit doesn't have any information on your phone, that doesn't mean we can't be of assistance.
This same repair has been addressed on here previously; see the following post for information on replacement parts and instructions.
Need a new screen
da
Aggiungi la tua risposta
Lily Mung sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 35
Tutti i Tempi: 882
