Salta al contenuto principale
The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
Why is my wifi and bluetooth not working
Why is my wifi and bluetooth not working Why is my wifi and bluetooth not working
Questa è una buona domanda?
Punteggio 102
29 Commenti
Has the phone been dropped or damaged at all?
da
I did factory reset but still not working
da
I went in my hardware but my wifi and bluetooth are not listed in and its says unavoidable
What must I do
da
I'm having the same issue on my Samsung Galaxy Note 20 Ultra. After the new update, they both stopped working.
da
Check (verify) the time zone on your phone. I had this problem On the last update and resetting the TIMEZONE corrected the problem.
da
Mostra altri 24 commenti
Aggiungi un commento
30 Risposte
Risposta Più Utile
There could be several reasons why your WiFi and Bluetooth are not working on your Samsung Galaxy A10s. Here are a few things you can try to troubleshoot the issue:
  1. Restart your phone: Sometimes, a simple restart can fix minor software issues.
  2. Check if the WiFi and Bluetooth toggle switches are on: Go to Settings > Connections and make sure that the toggle switches for WiFi and Bluetooth are turned on.
  3. Check if the WiFi and Bluetooth chips are enabled: Go to Settings > About phone > Hardware information and make sure that the WiFi and Bluetooth chips are listed as enabled.
  4. Check if there are any software updates available: Go to Settings > Software update and install any available updates.
  5. Check if there are any issues with the router: If you're trying to connect to WiFi and it's not working, try connecting to a different WiFi network to see if the issue is with the router.
  6. Reset the network settings: Go to Settings > General management > Reset > Reset network settings. This will reset all the WiFi and Bluetooth connections on your phone.
  7. Factory reset your phone: If none of the above solutions work, you may have to perform a factory reset of your phone. Keep in mind that this will erase all the data on your phone, so be sure to back up your important files before doing this. To factory reset your phone, go to Settings > General management > Reset > Factory data reset.
Punteggio 28
37 Commenti:
I did factory reset but it still doesnt wrk
da
Hi I did all but didn't work
da
After the last Samsung update my wifi and Bluetooth isn't working as well
da
Same for me, bluetooth and wifi can't be on. when I tried to open it it'll become off again.
da
Same here to me
da
Mostra altri 32 commenti
الخلل في ايسي بلوتوث والحل استبدال الايسي او تسخينه راح يرجع الجهاز طبيعي
Google translate:
The fault is in the bluetooth eSee, and the solution is to replace the eSee or heat it up, and the device will return to normal
Punteggio 10
10 Commenti:
how to replace the esee or heat it up?
da
Oh my gosh I did everything but still won't connect I'll just chill here and wait for the answer
da
I am facing the same problem. My Wifi and Bluetooth is no longer working. Is there any Samsung Technician ca help me fix this problem? Thankyou.
da
I am also facing this issues wifi and Bluetooth devices is not working plz tell me solve the solution plz
da
Even if I refractory doesn't work
da
Mostra altri 5 commenti
If your WiFi and bluetooth not working it is because of Ic problem you have to change it
Punteggio 7
2 Commenti:
I did perform factory reset but still the same. Help me out pls
da
How can we replace Or heat it where it is inside the phone?
da
If you have WhatsApp installed. Try cleaning WhatsApp data or uninstall WhatsApp. It works fine for me. A10S
Punteggio 4
4 Commenti:
It's a hardware issue. The phone's IC has a problem that's why the Bluetooth n WiFi don't work. The technician will demand approximately R250 to R350 to fix it.
da
No hardware issue this is new update issue.
da
Not an update issue. My phone has not received an update in years because it an old phone (Galaxy J5 prime). So it is a hardware issue-
da
My Samsung a10s have the same problem
da
turn on bluetooth to connect to nearby devices
Punteggio 4
1 Commento:
Still my phone doesn't want to open
da
Reset your Wi-Fi router. The location of the reset button depends on what Wi-Fi router you are using but every Wi-Fi router has one.
Punteggio 3
1 Commento:
Thank you, Anthony, but this is not a solution to problem.
da
Why is my wife and Bluetooth working
Punteggio 3
Try to format your phone
Punteggio 3
Heat ic 300 ⁰c but how can i show the ic
Punteggio 2
Well I will suggest to do the software update or system updated of your phone. Sometime outdated software version can also cause these kind of issue as well.
Punteggio 2
3 Commenti:
You can't update phone without WiFi
da
Even if I restart don't enable and not op6
da
I did restart but still is not working
da
Its hardware issue my 2 devices one got resolved heating ic and second one had replaced ic MT6631N
Punteggio 2
Wifi end blootot hospot
Punteggio 2
WiFi not opening
Punteggio 2
1 Commento:
Since the problem occurred with all users of this version of Samsung, this means that its function was stopped in the latest Samsung update.
da
My wife and bluetooth are not working on my phone my phone is Samsung A10s
Punteggio 1
Punteggio 1
Bluetooth 11
Punteggio 1
1 Commento:
WiFi and Bluetooth connection is not working
da
I have an S20+ and a WiFi 6 home network. I'm running the May 2023 update to OneUI 5.1.
Suddenly last night I was unable to connect to my home WiFi network. WiFi worked fine for all my other devices. I did lots of Google searches.... After trying all the obvious simple things (toggling Airplane Mode, Rebooting the phone, etc.), I looked in the S20+ Settings / Developer Options this morning and found "WiFi non-persistent MAC randomization" and turned it ON. WiFi almost instantly started working again on the phone.
I hope this helps others.
Cheers,
Scott.
Punteggio 0
My wifi and bloototh not working
Punteggio 0
My wifi and Bluetooth malfunctioning since last 2 months
Punteggio 0
Why my wife and bluetooth not working on network
Punteggio 0
5 Commenti:
da
My bluetooth and wife are not working my phone is Samsung A10s
da
Me 2 my Samsung A10s is not working
Bluetooth, WiFi and hotshot won't connect
da
My wifi and bluetooth not working
da
My Wifi and Bluetooth is not working in Samsung s20+ and developer option is also turned off
da
Punteggio 0
My wifi & bluetooth not working, I have samsung Fold 3… .I got sick of samsung, Im going to buy Honor magic v3
Punteggio 0
Wifi Bluetooth not working why problem factory already but not solve
Punteggio 0
Why Bluetooth say disconnected
Punteggio 0
1 Commento:
Answer me plz
da
I do no but it's is in software complaint
Punteggio 0
How i can fixit
Punteggio 0
Punteggio 0
I don't no but I want to learn
Punteggio 0
f your Wi-Fi and Bluetooth aren't working, start by restarting your device and router, and check for simple issues like interference or drivers being outdated. If those don't work, try resetting your network settings, which will erase saved Wi-Fi passwords and Bluetooth pairings but can resolve connection problems. For persistent issues, consider updating your system or, as a last resort, performing a factory reset.
Punteggio 0
Replace or shake the wifi and Bluetooth IC
Punteggio 0
Aggiungi la tua risposta
Yidnekachew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 48
Ultimi 7 Giorni: 190
Ultimi 30 Giorni: 702
Tutti i Tempi: 77,557
