Salta al contenuto principale
My JBL party box on the go will not turn on or charge when plugged
My device will not turn on when it's plugged into the wall. It is receiving no power at all when plugged in and the battery will not charge at all as well. I'm not sure exactly what to do to get it fixed or if there is a place where I can buy replacement parts to attempt a repair. Can anyone help me?
Questa è una buona domanda?
Punteggio 6
3 Commenti
When I plug my speaker the power button turn orange and it’s not showing that is charging. When I unplug it, it just disappeared. I tried everything! I think that maybe it might be the battery. Can you help me? thanks!
da
My JBL party box 100 Won’t charge and will show the power button and Bluetooth button on for a second and will turn off
da
My JBL PARTY box 300 is not turning on no lights no power on
da
Aggiungi un commento
11 Risposte
Risposta più utile
It happened today with my JBL Partybox ON-THE-GO. The speaker was neither switching on nor showing any light for charging while power cable was plugged in.
I tried to use various combinations watching YouTube videos but found the that Bluetooth and Power button pressed together for 10 or more seconds brought back the speaker.
Hope it will work for you also. Try your luck! 👍
January 25, 2023
India
Punteggio 8
13 Commenti:
OMG i love you! Thank you sooooo much!!! It worked on mine
da
is that true the power is back when you do this? i thought its dead battery ..i want to try this if this work thanks i advanced
da
This trick actually worked lol I was a skeptic thanks.
da
Thanks Bros and Sis, I just won a JBL Party Box on the Go in a lottery, now I know what to do once this happens to my Box.
da
I have a dragonfly t8000 party speaker no power at all it's new I checked the fuse it was blown ,I put a new one in it still no power.do you know what it could be.
da
Mostra 8 altri commenti
@luigi25th, There are a couple of things to try, before taking it apart to replace something.
Use a DMM (digital multimeter) to check the output voltage on the charger, as it could be gone. If it shows no or very low voltage, you know that it’s your charger that needs to be replaced.
It could also be the battery that’s toast, because some systems have a security system built in that will prevent charging and powering on, if the battery is dead.
If you find that the output voltage is OK, you’ll have to disassemble the device in order to gain access to and replace the battery. I believe that the part number for the battery is: SUN-INTE-265
Punteggio 1
1 Commento:
da
I bought a party box 310 that wasn’t charging and the issue ended up being that the battery was too depleted for the speaker to charge it. To fix it I pulled the side panel off and removed the battery and took it down to battery world to plug it in to their smart charger, charged the battery for half hour then put it back in the speaker and problem solved. Now it works perfectly. So if the battery is too dead, it won’t charge in the speaker.
Punteggio 1
1 Commento:
how do you charge the battery outside the speaker?
da
My JBL is not working, I have plugged it in all circuit gadgets and still not turning on?
Punteggio 0
1 Commento:
My speaker doing the same thing
da
its not worked on mine but thanks for help
Punteggio 0
When I have, it plugged in. It flashes from orange power button to white, bluetooth, back and forthWhen I have, it plugged in. It flashes from orange power button to white, Bluetooth, back-and-forth.
Punteggio 0
Mine won’t turn on, but if I leave it unplugged for a while and plug it in, the dots above the power button light up (except the first closest to button) then nothing happens. I even tried letting it die and quickly pressing power when it lights up but nothing. Tried it 5 times, out of 5 once it turned on but I couldn’t turn it off. Not sure if a battery problem or a power switch prob.
I’ve abused this speaker for years and it hasn’t popped so I know I can get more out of it. Hoping someone can help instead of me spending 500+ tax on a new one.
Also called a local repair shop and they want 45 to inspect then parts and labour on top. lol if that exceeds 200 I might as well buy the 120 with swapable battery. Idk what to do. I think it’s the battery but I’m no expert.
Punteggio 0
My blue tooth speaker is not working I plugged it into wall and turn it on and it say blue tooth and blue light come on then it cut off when red light come on will not play keep cutting off
Update (03/24/25)
Blue tooth will not play keep cutting off when I turn it on i plug it in wall turn it on blue light come on it say Bluetooth then red light come on then it cut off
Punteggio 0
1 Commento:
What is the manufacturer and model of your speaker?
da
My speaker doesn’t turn on anymore. I Thought the battery was dead, so i measured it and it was. Now i bought a new battery and it still won’t turn on. Has anyone any clue?
Punteggio 0
1 Commento:
The same thing has happened with mine and I did the same thing still not working either
da
It cut on but turns off I need help
Punteggio 0
1 Commento:
My speaker don't have a battery just plug in the wall lights up an then cut off I need help have a party tomorrow
da
Last night on but naw am start no light no on
Punteggio 0
1 Commento:
My Party box Club 120 was working fine last night and today apparently wont charge 5th September 26
da
Aggiungi la tua risposta
Luis delval sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 10
Ultimi 7 giorni: 74
Ultimi 30 giorni: 483
Tutti i Tempi: 41,805
