Salta al contenuto principale
Modello versione metà 2009 A1278 - EMC2326 / processore Core 2 Duo 2,26 o 2,53 GHz
738 Domande Visualizza tutte
Can this system still be repaired or it is a throw away?
I will try to tell all the information I have:
I bought system off ebay for display spare parts, once I changed the display and I decided to test the logic board of the system and the following things happened
1) there is a 45w power supply green led
2) connecting the battery - it is recognized and recharged
3) by pressing the start button the system starts and after 2 seconds it turns off and after 2 seconds it turns on again, after that the system is started only that the display does not show anything it is black, I also tried connecting the external display - nothing
4) I measured the voltage on the components that appear to be in the screen power supply chain on the diagram, they are all at 0v
the motherboard is 820-2530
I want to know if the gpu is dead, if it is still repairable in the sense that I would use it without its screen - via DP cable with external monitor so I don't care that the notebook display doesn't work
Update (12/28/2022)
https://drive.google.com/drive/folders/1...
Questa è una buona domanda?
Punteggio 0
25 Commenti
do you have the boardview and schematics for it
da
@tech_ni yes how i can add them here ?
da
@Game FullHD i have them i was just asking if you did
da
@tech_ni yes i have , so what we can check to say if gpu is dead or no ? consider that now I can only connect the power supply , when the power supply is connected there is a green light but it does not start , probably because it is a 45w which is not enough so I now take the measurements in s5 state
da
@Game FullHD do you have 3v3 on pins 2,3,4 of the lvds connector
da
Mostra altri 20 commenti
Aggiungi un commento
1 Risposta
Soluzione Prescelta
U7200 fault .........
Punteggio 1
1 Commento:
check r2852 for allsyspwrgood
da
Aggiungi la tua risposta
Game FullHD sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 122
